98 Camry headlights
Grizlo
01-05-2004, 09:47 AM
I had a turn signal that would blink at double speed when headlights were on. I learned to live with that. Today however, my turn signals and hazards stopped working all together. Any ideas on what this could be?
kisswahili
01-05-2004, 12:52 PM
hey men the same thing happened to me last night....one minute my turn signals were working fine then thenext minute they just died.....plus my hazard signal doesnt work either.
i checked the fuses there all good......any more ideas?
yotatechie04
01-06-2004, 02:53 AM
Underhood relay. Check all of your relays and fuses under the hood, I figure that is your problem...I had the same problem with mine, and the relay just burnt out. After replacing it, they worked just like before.
kisswahili
01-06-2004, 08:16 AM
are the relays in the same place as the fuses ....the fuse holder next to the battery?...
how do i know which one is the relay and how much do they cost
yotatechie04
01-06-2004, 04:59 PM
The relays are in the little black box beside the battery. On the inside of the cover, there is a diagram that tells you what relay is for what, very similar to the fuses inside the car. The relay shouldn't cost much, depending on where you get it, it should be relatively cheap, that is if you go to a discount auto part store, such as Advance.
kisswahili
01-07-2004, 08:19 AM
right on it
