Throttle Box
Google
Web AF
kingsta82
01-03-2004, 12:57 PM
I have a 2000 Silverado Z-71 with 75,000 miles. When starting from a dead stop my accelerator requires a good hard push to start moving. Once free, the push usually causes me to spin burn a little rubber while getting under way. The problem is interrmitant and I heard on car talk that my throttle box may have excessive carbon build-up and require cleaning. However a coworker had the same problem and had to replace the throttle box. Any ideas?
Slowprocess
01-09-2004, 12:26 AM
You do not have to replace the box. THe throttle body just needs to be cleaned. It is a well known fact that the dealers use that to make you buy a new one. Just clean yours and you might have to make an adjustment on your throttle body. Either one of these will fix your problem.
Google
Web AF
