93, won't start one minute, will the next no spark
Google
Web AF
dalex50
01-02-2004, 07:25 PM
I have a 93 sub, it will start fine one minute, an hour later it will crank but will not start, geting plenty of gas. Seems like there is no spark from ignition. Can come back next day and it fires up on first turn of the key. Any ideas?
toivo
01-03-2004, 01:23 AM
check coil connections, coil wire, could be a broken wire from the pickup coil inside the distributor. sticking oil pressure switch. or bad ignition switch. maybe even a bad switch from the tranny selector, nuetral, park, position switch.
dalex50
01-03-2004, 05:00 AM
thanks a lot. will check these out today. thanks for the quick response
blueburbboober
01-03-2004, 03:03 PM
a diagnostic computer will probably be able to tell you the problem, even though it only has obd-1, you still should be able to pick up a trouble code from something like that. start with the easy things first to test, itll save you time and money :-)
-Rob
Google
Web AF
