hinge pinstoivo 01-02-2004, 04:19 PM what is the secret to popping out the hinge pins on the cargo door on 97 suburban? i can't get them to move and the doors are wobbling badly. Regency Burb 01-02-2004, 11:59 PM Haven't done it but heard from a body shop that you have to replace the whole door. toivo 01-03-2004, 01:31 AM that is a horrible, very bad, icky answer, please try again. thanks for the info. toivo toivo 01-06-2004, 03:15 PM i went to the chevy garage and the man said they cut the hinge open with a grinder, remove the pin, squeeze the hinge back together, then weld it and paint it and drive in new pins. so totally unsophisticated. has to be a better way in america. jjwg3 01-06-2004, 06:44 PM My doors got really tight so I thought I would change the pins and bushings...Wrong!! I couldn't budge them. More than one source told me "Good Luck!!". I then heard the same thing about doing damage to change those pins and I gave up. In my case, I kept up the penetrating oil doses and worked the doors until I felt it was the best I could do. Now I just live with a snug door. Sorry to hear yours are wobbly, oil won't help...John ty250 03-12-2004, 02:31 PM the hinges on my '92 were extremely tight too. Penetrating oil didn't seem to make much difference. With the door open, I was able to drill a very small hole on the inside of the hinge , then use a chain saw bar greaser to inject grease. I have to regrease every six months or so, but the rear doors open much easier now. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
