Speedometer help neddedBulletTooth 01-01-2004, 05:12 AM I have a weird problem with my speedometer. It shows the speed a little higher than the actual speed by about 10% or 5MPH, however my OBC seems to read the speed ok, is there any way to adjust the speedometer to read the speed correctly? Thankx for your help! Filehorse 525i 01-07-2004, 08:04 PM You have just come face-to-face with a BMW-designed error. In Europe, there is a stiff penalty if a car manufacturer puts out a speedometer on which the displayed speed is less than the actual vehicle speed. To ensure this doesn't happen, BMW designs in a bias where the speedometer will always read ~5% higher than the actual speed. I've posted this same question and based on what I've been able to find out, there is no apparent fix. Like you, I figured there must be some "adjustment" where you can calibrate the speedo. If it's there, I haven't found it yet. It really annoys me when the average Dodge Stratus has a more accurate speedometer than my 2002 525i. The error only affects the speedo. The odometer is not biased. :banghead: BulletTooth 01-08-2004, 01:15 AM Thanx for the reply. I guess I'll just have to live with it. What's weird is that the OBD reads the speed correctly. I have my limit set at 80mph and it sounds the alarm at exactly 80mph at which time my speedo actually shows 85 already, that's why I thought that there might be a way to fix this problem. If anybody else has any takes on this subject I will sure appreciate it. Filehorse 525i 01-08-2004, 04:56 PM You also correctly noticed that your average speed calculation and your speed alarm are correct. It's only the analog speedometer that's affected. I noticed the error when comparing it to my StreetPilot III. If you ever discover a "fix", please send me the link. Otherwise, just drive faster....!! :smokin: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
