97 Ram 1500 Stalling. HELP
sasquatch2550
12-31-2003, 08:21 PM
HI, I just replaced the spark plugs, pcv valve, and oil and filter myself and now my truck is stalling at idle speed in gear. Could the pcv valve cause this or do you think it has to do with the spark plugs. 5.2 liter v8
Any Ideas are appreciated, Thanks, Jeff
92'rs boy
01-01-2004, 03:59 AM
hey did u check your battery that is what happened to our truck it kept stalling. jus thoughti would put my 2 cents in. also could be the oil filter maybe your valves aren't on right and it is gettin to much or too little oil. see ya good luck
jrwpmw
01-02-2004, 11:27 AM
Are your plugs gapped correctly?
Are you ABSOLTUTLY sure that you didn't crack a plug when installing it? Maybe dropped it on the floor? It's very easy to crack the ceramic!
Also, are your wires on correctly? Maybe you didn't one back on right, or busted it when you took it off?
Make sure you didn't knock off a vacuum hose.
If you have more than 60,000 miles on your truck, toss some new wires, cap and rotor on too. You can do all of that for less than $50.00.
sasquatch2550
01-02-2004, 02:11 PM
is there any way to tell which if any of the plugs broke when installing, or do i have to pull them all out again? They were gapped from the factory, so i didnt check. also, i cant find a cap or rotor in the engine compartment, i think its efi, its the 5.2 v8 97 thanks for your responses guys!!, JEff
jrwpmw
01-02-2004, 05:26 PM
Ahh.... the plugs were gapped at the factory. Pull them and check them! You might be surprised.
I have a 98 5.2 Dodge RAM, your cap and rotor are in the back of the motor. Just take your air cleaner off and it's not too bad to access.
Just to be sure, you should be able to shake the new PCV valve and hear it rattle. A new one could be defective, but not likely.
sasquatch2550
01-02-2004, 08:53 PM
HI, i took out the plugs and they were gapped .35 and the maual says .40 so i regapped them and it seems to have helped, would such a small difference really change much?, Jeff
Mtngoat
01-06-2004, 12:44 PM
I have a 5.9L V8, and had intermittent stalling. I had to replace the IAC (Idle Air Control). I havent had a problem since. I am not sure if you have the same problem, but I thought I would throw this in...
pkupmanvt
03-07-2004, 10:07 AM
this valve can also be removed and cleaned
zakimodo
04-11-2004, 09:33 PM
i had a stalling problem that i thought i would never fix. even the mechanics were stumped. while examinind the underside of the truck i found a wire hanging above the drive shaft to the front axle. the seathing was worn off and when it was hitting the drive shaft in 4 wheel drive it woold ark across and shut the pickup off.
cbr310
04-12-2004, 04:06 PM
Where is the IAC located at and what does it look like? Going to clean mine.
Justan02Ram
04-29-2004, 11:40 PM
The IAC is on the throttle body, take it off and clean it with some carb. cleaner, also while you ahev the t-body off clean inside of the barrelsopen it up and you will probably see a good amount of build up on the walls. Hope this helps
slantsixness
04-30-2004, 07:20 AM
My two cents:
THe IAC is cheap. Replace it. When it does go bad, it'll leave you in a parking lot, and Very pissed off!
Usually it'll only give you trouble when tou try to start or idle. If you're driving when it fails, you're still going to get where you're going, just not back!
Cleaning the throttle body is an excellent idea too.
Also, the damn IAC going bad will foul your brand new plugs very quickly (1 day or so, depending on idling time in traffic.). So check them again, once the ordeal is over.
Slantsixness
