oh please help!!! 94 firebird wont start94formulafbird 12-30-2003, 12:39 PM ok here's the deal... i have a 94 firebird that wont start. I am getting spark to all cylinders and have recently replaced the distributor module that goes behind the water pump which my dad thought was broken but ended up being fine. I KNOW it is a fuel issue because A) when i shoot engine start fluid down the throttle body and turn the car over it starts and dies. I have taken off the whole injector and fuel rail assembly and tried to start the car and found that the injectors weren't even firing. I know the fuel pump is pumping although i lack a fuel pressure guage to see how much pressure it is providing. My question is this.. could the culprit be the ECM? which in my experience is not the first place to go looking for a problem but thats the only other thing i can think of that would cause the actual injectors not to fire. Or are there any other factors that i am not considering. Anyone who can help me with this will be my hero! Another little tidbit of info. After the car has sat for a while it will fire up and die as if gas has leaked out of the injectors slowly over time or it could be the startup injector .. not sure but... anyways Maple50175 12-30-2003, 09:34 PM Hey man Yeah I havnt started my 89 firbird in like a year.. It like took forever to start and i had to jump it and it started but i turned it off because the engine i thought was going to explode then i tryed starting and it wouldnt fireup blah It sucks i know what ur going throught 94formulafbird 12-30-2003, 11:33 PM yeah i just wish that i could figure out why the injectors wont fire i already pulled off one of the fuel lines to see if the pump was pumping and sure enough i got a bowl full of gas in a few short seconds if anyone has any ideas please tell me or email me at s7thblackpony@hotmail.com Ron22 12-31-2003, 09:10 AM Hi, I am Ron from Sweden and i also have huge problems with my Pontiac. I will try to write so you can understand my bad english. Ok, Do you have a V6 or V8? Becuase i don't rekognize that place of the ignitionmodul. Do you have spark, are you sure the spark comes when it should? About the fuel, you are sure that you get fuel to the injectors? You can measurment the injectors. If you have a digital volt and Ohm instrument, take away the contact to the injector. Then measurement the injector itself and it very healthy one should show 16 ohm and its ok down to 8 - 10, but under 5 ohm then its something wrong. You closer to 0 ohm you get worse it is. Have you check the MAF sensor (i suggested you have that on 94). Write your progress or symptom and we will try to figured out whats the problem. My car is also a pain in the ass right now but you know... don't give up... Happy New Year... Ron22 Sweden 1Formula 01-02-2004, 09:59 PM fuel pressure regulator. savage68 01-08-2004, 01:40 PM how can you be so sure that its the fuel pressure regulator? Isn't that just the screen infront of the fuel rail that filters everything out? 95fbodyunder3k 01-25-2004, 11:18 PM u need at least 40 psi of fuel to run mpi injectors so u need to find out if u have at least that much pressure at the service port on the fuel rail a weak fuel pump will spray gas but it may not go through the injector u can get a fuel gage from most part stores for 30 to 50 bucks if yer a do it your selfer it is a good investment :) xl125rider 01-27-2004, 06:06 PM hey dude i dont know if this wil help but my dad a long time back mentioned something about fuel and he got an air compressor and stuck the nozlle into the gas inlet and gave it just a couple of pounds of gas....now i guess you could try it not sure if it works but take a whack at it.... welll good luck hope ya get it running FormulaLT1 02-03-2004, 04:22 AM Well I always found that the simplest answer is usually the correct one, So if your car has pressure at the pump and when it sits or has fuel manually sent into it , it starts up , it can only be one of three things, 1. It can be a clogged fuel filter but it would have to be the worst I ever heard of the cause the car wont even start. 2. a Clog in a fuel line or rail . 3. Your injector's went bad (in which case you should buy a injecter cleaner the aerasol can that connect's to your rail and spray's the cleaner right in the injector's. Also you really need to invest the $20 into the fuel gauge it will be a big helps in finding the problem. GOOD LUCK dena_marie 02-04-2004, 10:27 AM Had that happen to me too on my 1991. It wound up being a leaking fuel line. I had the injectors replaced and it did the trick... $1000 later. I had tha battery replaced thinking that was the problem, but we were always jumping the car because it only ran when it was actually running, if we turned it off, it wouldn't start again. xjoeharperx 02-04-2004, 10:47 AM You need to check the cam position sensor and crank position sensors. Im not a specialist on these cars but generally of one goes out it wont give the siginal to fire the injectors. hot_red_z28 02-04-2004, 03:53 PM While turning the key over, hold the pedal to the floor. (I'm not joking) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
