Remote Programming
Google
Web AF
bigboy9600
12-30-2003, 10:07 AM
Hi
I just bought a brand new 2004 Chevy Express 3500 it came with 2 remotes but I need to get more then that. If anyone would be able to help me out with programming remotes for that van I would greatly appreiciate it.
Thanks
dpcrane
01-20-2004, 01:36 AM
Since you bought it new, your dealer should be able to program additional remotes. They want $36 to do my added remote on my 2000. I have seen instructions on other Chevy threads for different models, but haven't found one that works, yet. Check on Ebay to get a good price on additional remotes, but make sure the code matches.
spotco2
04-06-2004, 10:11 PM
Transmitter Programming
Important
All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. Up to four transmitters may be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number on the transmitters are for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available. Use care to program the transmitters correctly.
1. Install a scan tool.
2. Turn ON the ignition, with the engine OFF.
3. Use the scan tool Remote Function Actuation Special Function: Program Key Fobs in order to place the remote control door lock receiver into Program Mode. The doors will lock and then unlock in order to confirm program mode.
Important
The scan tool must stay connected until all of the transmitters are programmed.
4. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 15 seconds, the doors will lock and unlock in order to confirm the programming of that transmitter.
5. Repeat the previous step in order to program up to 4 transmitters.
6. Remove the scan tool.
7. Operate the transmitter functions in order to verify correct system operation.
" name=forward Document ID# 641243
2004 Chevrolet Express
Google
Web AF
