windows misting up on 320i 1996 auto
Google
Web AF
matrix2004
12-30-2003, 04:03 AM
hi i hope someone out there can help me my 96 320i auto has got a problem with the windows misting up and only clear up when i put the ac on and living in england and at winter time its cold.
the car i belive is an import from malasia
many thanks for you help,
also the rev counter goes past 4500 when you are moving if but the car doesnt sound like its reving that high
Nickell100
01-01-2004, 11:28 PM
The reason your air conditioner clears the windows is because water is removed form the air when it passes through the air conditioner unit, thus there is no vapor in the air to condense and fog up on your windows. So air conditioning is the best way (I know) to clear windows, and you should know that it will work with the heat on- hot air conditioning sounds a little strange but it clears the windows fine. Hope you figure it out..
Filehorse 525i
01-06-2004, 07:47 PM
Be sure your ventilation system is not in the Recycle mode. This is guaranteed to have the windows fogged up in short order in the winter time. Moisture from your breath accumulates until the glass temperature is below the dewpoint of the air and - presto - condensation. For what it's worth, my E30 almost required that I run the A/C in winter to deal with your problem. Fortunately, my E39 seems to breathe much better.
:smokin:
shtamp
01-07-2004, 06:26 PM
Check antifreeze level, any leaks under the car (windshield area).it is possible you have a leaky heater core which might cause the misting windows. I just replaced mine on 325i ’92.
Google
Web AF
