1996 Cherokee driving me nuts.
Google
Web AF
grizzlybear310
12-29-2003, 10:08 AM
First a little background on my Jeep.
It's a 1996 Cherokee with 130000 miles on it.
I use it ever day on a 90 mile stop and go run.
I deliver the local daily newspaper in my area.
I have had it since October and after I first got
it, it had a problem with wanting to miss and act
like it was running out of gas.
It would only do this after about 80 miles or so.
I took it back to the dealer and he had his mechanic
drive it till it started doing this and then he hooked
it up to the computer and found nothing, no codes
were on there.
No check engine light ever came on.
He then took it to another place to put it on their computer
with the same results. No codes.
So, he put a fuel pump on but not the pressure regulator.
New cap, plugs, wires, rotor, even a distributor.
No good. Same thing. After about an hour and a half into the run, start acting the same way.
I talked to some people and after that, I put an 02 sensor on and it ran great up till 2 days ago.
Now, it is doing it when you go up a grade.
It is like you have the gas pedal pushed down and then let it up and then back down again.
A surge if you will. No missing, no acting like it's running out of gas, just the surging.
Not on flat ground, just when you are going up a grade.
I am at my wits end with this thing.
Has anyone got any ideas?
Could the fuel pressure regulator be doing this and if so, why wait so long before it starts?
Thanks in advance.
Going nuts in Kentucky.(Lester)
grizzlybear310
01-02-2004, 07:53 PM
Update.
Have tried a couple things and no good.
I think I may have found it, but will know more tomorrow for sure.
Am trying one more thing tonight and will take it on my run in the am to see if it fixed it and will let you know.
grizzlybear310
01-03-2004, 07:18 AM
Update;
Well found out a couple things.
1) My Jeep is a change over Jeep as in a late '96.
Found this out when went to buy a CPS for it.
All the parts houses had one for a '96, but was different than mine
and they did not have it so, had to go to dealer and after giving him
my last 6 digits of my VIN, they told me that it was a change over
model and it took a different CPS.
Well after $122 and change, no different.
Now here is some more ammo for you fellows to see if you can figure
it out.
It was warm here this am and I was riding around with my windows down.
I noticed a faint smell of gas and right after that, it would start
running bad again.
This time I mashed the gas a little more and it would backfire
through the intake it sounded like.
Now another clue, I could stop, turn engine off, count to 5, start
back up and run like a champ for about 20 minutes or so and it would
do it again.
Again, I would shut it off and start it back and it would run fine
for a little while and right back to the problem.
Each time it would do this, I could smell some gas fumes right before
it acted up.
Please help, I am out of options on this thing.
Lester
XJnick
01-03-2004, 06:23 PM
Hi,
1996 Model year Cherokees are known for having fuel system problems.
It sounds to me like you either have:
1) A leaky vacuum or fuel vapor line somewhere
2) Leaking injectors (you smell excess fuel being burned upon start-up)
3) Bad gas cap or slight leak in filler hose allowing the system to loose vapor pressure.
4) Exhaust system or EGR system leak
Other than those possibilities, it would probably be a computer related problem.
-Nick
grizzlybear310
01-03-2004, 06:35 PM
Hi,
-Nick
Thanks Nick.
First it does not have EGR valve.
I do not smell gas on start up and the injectors are not leaking.
Repaced gas cap with new one and it will build pressure up after running.
Did a pressure test and system holds 49PSI even after engine is shut off for 20 minutes.
I am now getting ready to replace the MAP sensor and see if that helps.
This is a late '96 with a lot of '97 parts on it I am finding out.
grizzlybear310
01-04-2004, 08:59 AM
Another question.
Could it be possible that the coil is heating up and breaking down?
The reason I ask is that this morning while out on my run, it started it's stuff and the check engine light came on this time and after I got back home, check the code and it is a #43 which is;
"Peak primary coil current not achieved with max dwell time or
Cylinder misfire", which could be caused by the coil if I am correct.
Anyway, I am going to put one on and see.
Will let you know the outcome.
I will solve this mystery yet if I don't run out of money first.
Lester
XJnick
01-04-2004, 09:23 AM
Hi,
I'm really not sure if it is possible for a coil to act up only when hot. I've heard that the coil either works or it doesn't, though. Maybe you could let the Jeep heat up and then check for spark from the coil.
You may just be getting #43 due to mis-fire. I've gotten that code before on my wrangler with just the very slightest misfire. It seems to be a very sensitave code.
-Nick
grizzlybear310
01-04-2004, 09:28 AM
Thanks again Nick.
This misfire was enough to make it quit this time so I am going to put a coil on and see what happens.
Won't hurt.
XJnick
01-04-2004, 09:30 AM
Good Luck.
Don't give up on it yet... :D
-Nick
grizzlybear310
01-04-2004, 04:10 PM
Update:
I did the coil swap and went out and drove it for about an hour with no problems.
On the way back I stopped and took off and crowded it quit a bit and it wanted to stumble again, but as soon as I let up on the gas and drove it normal, no problem. Just when I get on it heavy.
Now what?
Thanks again.
Lester
96Classic
01-08-2004, 08:41 PM
Does it blow any smoke from the exhaust?
richpinkham
01-09-2004, 06:29 PM
Have you ever check to see if the fuel filter has been replaced? If its like the older cherokees it has a fuel filter on the inside of the frame above the rear axle on the drivers side. It maybe getting fuel at a low speed but not under demand. Something to check and its cheap to replace it it hasnt been done.
grizzlybear310
01-09-2004, 07:27 PM
First let me say that I have been checking things out quite a bit on this thing.
I took it to the Jeep dealer and had them run their tests on it and they found nothing but a slight little bit of rust in the fuel rail and they said that it could cause it if it got into one of the injectors.
They(head tech) told me this was a 4.0HO from 1997 in this Jeep and it should have been titled a 1997 instead of a 1996.
Anyway, he took it out and drove it for 25 miles and said it was one of the best running 4.0's he had drove except for the problem after it got warmed up.
It would only do it after it was warm, not cold.
He also advised getting a new muffler cause mine was swelling some and it may cause some back pressure.
I went straight and put a new one on it.
I am still waiting on the cleaner to take care of the rust before I have to take it to get the system flushed out.
P.S. To answer your questions, no it does not blow smoke other than regular exhaust and yes, it has a new filter on it also.
j.leo
02-29-2004, 02:46 PM
I HAVE SIM PROBLEM SO FAR PEP BOYS REPLACED COIL, 3DAYS LATER PROB. BACK THEN DEALER REPLACED FUELPUMP ASSEMBLY, AND RADIATOR, 3DAYS LATER PROBLEM BACK, THEN DEALER REPLACES FAULTY COIL, 3 DAYS PROB, BACK, PEP BOYS HONOR PARTS AND LABOR THEN DEALER INSTALLS CRANK SENSOR NO CHARGE! (THANKS ) BUT YOU TOOK $1400 FOR FUELPUMP AND RADIATOR AND LABOR, 3DAYS LATER PROBLEM BACK , NOW DEALER SAYS CAT CONVERTOR IS BAD WANTS $600, BUT SETTLES FOR 200, BUT NOW WAITING 3 DAYS TO HEAR, gUESS ITS NOT FIXED OR HOPING MIRACLE HAPPENS IN SHOP OVER NIGHT, I FEEL YOUR PAIN AND HOPE YOU AND OR THIS FORUM CAN FIND THE CURES!WAITING DAY AND NIGHT FOR FORUM HELP!!!!!!!!!!
grizzlybear310
02-29-2004, 04:56 PM
I am down to the fuel pump regulator which is on my fuel pump and not on the fuel rail.
Dale Aeppli
02-29-2004, 09:10 PM
I HAVE SIM PROBLEM SO FAR PEP BOYS REPLACED COIL, 3DAYS LATER PROB. BACK THEN DEALER REPLACED FUELPUMP ASSEMBLY, AND RADIATOR, 3DAYS LATER PROBLEM BACK, THEN DEALER REPLACES FAULTY COIL, 3 DAYS PROB, BACK, PEP BOYS HONOR PARTS AND LABOR THEN DEALER INSTALLS CRANK SENSOR NO CHARGE! (THANKS ) BUT YOU TOOK $1400 FOR FUELPUMP AND RADIATOR AND LABOR, 3DAYS LATER PROBLEM BACK , NOW DEALER SAYS CAT CONVERTOR IS BAD WANTS $600, BUT SETTLES FOR 200, BUT NOW WAITING 3 DAYS TO HEAR, gUESS ITS NOT FIXED OR HOPING MIRACLE HAPPENS IN SHOP OVER NIGHT, I FEEL YOUR PAIN AND HOPE YOU AND OR THIS FORUM CAN FIND THE CURES!WAITING DAY AND NIGHT FOR FORUM HELP!!!!!!!!!! ALL VEHICLES DON'T ACT ALIKE WHAT TROUBLES ARE YOU HAVING WITH YOUR JEEP. STALLING, STUMBLING, CUTTING OUT & WHEN DOES IT DO IT jeepman600@aol.com
thebigbr
02-29-2004, 09:12 PM
I feel your pain buddy. damn vehicles eh! hang in there.
fergmonster
03-17-2004, 07:43 PM
i emailed the orginator of the thread directly on this one. i do believe that this is a case of "vapor lock".
the fuel lines must be getting too warm and the gas vaporizes therefore causeing this problem.
grizzlybear310
03-17-2004, 07:52 PM
Thanks for the reply but I do not see how it could be vapor locking when it only does this when it gets below a 1/2 tank,
Stop and put more gas in it and no problem.
I am in process of getting the regulator that no one has in stock through my dealer, ouch, and we shall see.
fergmonster
03-17-2004, 07:56 PM
i must have missed the whole 1/2 tank thing......
is the regulator located in the fuel tank? haven't gotten that far with my jeep yet.
it is definitely a pick up problem if it happens when you are changing your incline angle. have you dropped the tank?
grizzlybear310
03-17-2004, 08:08 PM
Yes it is on the fuel pump. Most are on the fuel rail, but not this one.
I do not have to drop tank to change pump and stuff on this one for it comes out the rear of tank.
Don't have to change incline, just get below 1/2 tank. Don't matter if your going up hill or down.
Again, thanks.
BTW, I have changed everything on this Jeep that ends in an S. :smokin:
nimsky
03-24-2004, 08:14 PM
Try replacing the fuel pump. They're known to break down and short out when warmed up, then recover like nothing happened when cooled down. The amount of gas in your tank will act like a heat sink, cooling it down and allowing it to work after only a few minutes after stall if full, longer if not. An in-garage pressure test won't reveal this, and the short or open won't occur until it's overheated. Good Luck.
grizzlybear310
03-24-2004, 09:26 PM
Well I kinda feel stupid. :banghead:
After doing it for 2 times, I let the Jeep run down to pretty close to empty and it still ran good. N/P's
But, I have been buying the gas at the same place for the last 2 weeks.
Now I kinda figure like I have heard other people say, that it does not like but 1 brand of gas.
I am going to test it again by getting gas at another place just to see, but it sure seems strange that it has not done this since getting the gas at this one place.
BCBlues
03-29-2004, 07:34 PM
Fuel Systems are sensitive.
I had an older Mercedes that did what your car is doing and it turned out to be a tank purge valve (pre vapor recovery vehicle) mounted by the rear axle had filled with mud over the years and at about half a tank It would run out of gas because internal tank vacume.
I have a 80 toyota 4x4 PU and it did the same thing twice. First time it was the vapor recovery system had totaly cloged and the old tank vacume thing did it again. The second time with the toy was due to a bad gas cap.
OK, "Jeep," this is the Jeep thread? LOL!!!....My 88 cherokee was sputtering and running out of gas on grades and when it was hot and hard to start when hot (didn't matter how much gas it had.
It turns out that the shop that installed the re-man engine forgot to put the little mount back on the intake manifold that keeps the fuel line from contacting the manifold and the Jeep was vapor locking from excessive heat on the fuel line.
I found this out by looking at Jeeps in the bone yard to compair. Installed the part and the problem was fixed.
It sounds like you have replaced a lot of stuff. There is some little thing like that mount that is hiding somewere (of corse you know that by now) causing your problem, be dilligant.
In the past I have had good luck fixing odd problems on used cars that I have bought by going to the bone yard and making compairisons.
Hoped this helped.
grizzlybear310
03-29-2004, 10:04 PM
Thanks BCBlues, but like I said it will run great on one brand of gas and like I also said, I tested it.
I let it get real low and bought gas at another place and run it and sure thing, it got to half a tank and did the same thing all over again, so I filled back up at my normal place I always use and no problem.
I feel kinda dumb at this point cause I had never had a vehicle to run just on one brand of gas before. :banghead:
BCBlues
03-30-2004, 01:06 AM
Perhaps the other gas station (bad gas) has water in ther tank.
You can check for this on your car by disconnecting the fuel line (after relieving the preassure) and pumping some gas into a clear glass container. If there is water in your gas you will see it at the bottom of the glass (the gas floats). There are various fuel treatments that you can buy that pour into the tank to cure this problem. I have had good luck with techron and stp gas treatments.
Good luck.
grizzlybear310
03-30-2004, 06:03 AM
Once again BCBlues, thanks again for the reply.
I have tryed this at more than one other station with the same results.
Gets to half tank and runs like crap.
I think I will just buy my gas where it runs the best.
dna fab
04-18-2004, 11:43 AM
check the catylitic converter it may run fine when cold then in side the cat may swell and redupower due to heat
dna fab
04-18-2004, 11:44 AM
check the catylitic converter it may run fine when cold then in side the cat may swell and reduce power due to heat expansion
grizzlybear310
04-18-2004, 11:49 AM
The Cat is new also.
Thanks.
Just a follow up. It runs like a champ all the way to empty on one place's gas so that is where I am buying it.
Thanks for all the replies.
wkumale
02-19-2006, 09:18 PM
I have a 96 cherokee... is there any way i can tell if it is a late 96 and has a 97 motor in it?
grizzlybear310
02-20-2006, 12:39 AM
Look on the fuel rail and on the end of it, see if there is a regulator on it.
If not, it's on the pump in the tank and most likely a '97 model.
musclegrl
03-03-2006, 04:18 PM
Replaced my cat. conv. - breakage inside caused hesitation problems. I heard some slight "clanking" sounds on idle that indicated loose metal somewhere. When my mechanic took the cat. off, it was pretty bad. Also replaced fuel filters but nothing else...no further problems. 1996 Cherokee SE
Google
Web AF
