my car dies while i am driving. then i stop and start it and it starts right back up.
Google
Web AF
traceylynnstef
12-26-2003, 09:54 PM
I am having problems with my 96 sebring lx. sometimes when i am driving my car just dies out and i have to stop put it in park and restart it. It starts right back up but i need to know why it is dying.Can someone please help me with this by telling me what may cause this problem.
tyvm,
Tracey
PS. YOU CAN E-MAIL ME @TRACEYLYNNSTEF2001@YAHOO.COM
Goose1970
07-03-2004, 10:02 PM
I've been going through similar problems, but sometimes it won't restart.
I would recommend getting the following checked thoroughly:
Ignition Switch. Inexpensive...might as well replace it.
Have you replaced battery recently? Make sure if so, whoever did it didn't take out a zinc washer the should separate the ACC and IGN power cables going into the POS terminal on battery.
Might be a good idea to check out the fuses....I've heard a good suggestion about resetting the computer by taking each fuse out with the key in the ACC position....remove each fuse 30 seconds apiece.
Good luck!!
SebringYves
12-17-2004, 05:27 PM
Check if you get a spark from the ignition system. Take off one spark plug, put a screw driver or somting like this inside the plug and bring it near to the engine block. The try to start the engine. If you donīt get a spark flashing from the plugto the motor block, the have the distributer changed. It will you cost about 300 dollars. I had the same problem and a lot of touble with this but finally its all solved.
bds545s
07-08-2005, 02:46 PM
I had this same problem with a mitsubishi eclipse once, which is essentially the exact same car under the hood. It turned out to be the computer which had to be replaced. I was able to buy a used one from an export salvage yard and a mechanic replaced it.
The problem is getting the car to stay broke long enough for a mechanic to perform tests to deterimine if it is the computer. If this is happening to you I would say it will eventually fail to start for at least an extended period of time.
Legendkiller
07-08-2005, 11:11 PM
i own a 1999 sebring and had the same problem when i bought it. For me, it was the Alternator Belt. Based on how you describe the problem, that would be my guess
bpolley
07-16-2007, 10:57 PM
Mopars are notorius for this. Old and new alike. 99% of the time it is a switch in the distributer. That part normally costs about $12. Save the headache of changing the switch and replace the distibuter. They really don't cost that much, i.e. if you can do it yourself. Otherwise $300 to $400. Good luck
TapOut64
07-18-2007, 05:18 PM
I just fixed my wife's 96 Sebring by changing out the MAP sensor for $60, took me 5 minutes. Her car was very intermittently stalling and hesitating.
twistedtech
07-28-2007, 02:01 AM
Holy crap,you'll be a month lookin at all that stuff. UMMMMM, just on the offsideways thought, maybe get it scanned for codes. Maybe the history codes might help. I have a 95 with a 2.5 and it needs plug wires BAD. Like for the last year. I just put the foot in the pan and up she comes.Expect anything more from a tech?
Google
Web AF
