how do i bypass the vatts system in a 93 buick lesabrejake43 12-25-2003, 08:01 PM how do i by pass the vatts system in a 92 buisk lesabre to install the bulldog remote starter without buying a module from bull dog Flatrater 12-26-2003, 08:58 AM Take a meter across your key pellet, then go buy a resistor of the same valvue install it across the 2 VATS wires at the base of the column. ponchonutty 12-26-2003, 11:02 PM how do i by pass the vatts system in a 92 buisk lesabre to install the bulldog remote starter without buying a module from bull dog Yep, just read the resistance on the key and then goto radio shack and get a resistor or combination of them that matches that code. The correct way is to use a reg. 5 pin relay and wire it so that when not remote started, the VATS works as it did before. Most amatures just wire it inline and totally bypass the VATS. :uhoh: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
