Prelude hard to start in cold
rodneys
12-22-2003, 09:19 PM
98 Prelude, Base.The last couple of mornings my car has been parked outside in around 20-30 degree weather,usually it's parked in the garage.
I go out to start it and it starts & dies 2 to 3 times,before it really starts running.Hasn't done this in the garage ,it's around 60 degrees in there.The rest of the day it starts fine.Checked the Dist. cap & Rotor Button.Was a little build-up, so I cleaned/sanded off. Bought a fuel filter,haven't installed it yet.Don't miss or anything either.Has 60,000 miles on it now.Have had to have the belts & tenser chg. about 15,000 ago.Thanks alot,
sofast
12-22-2003, 09:29 PM
Have you winterized your car yet. Make sure you check everything. A/F, fluids, gas treatment, battery/charging,etc. My prelude had the same problem when it started to freeze outside. I did some routine maintenence and have had no problems.
Happy Holidays
rodneys
12-22-2003, 10:09 PM
I have checked the battery and fluids,added fuel injector cleaner ,everything seems and runs good
rodneys
12-22-2003, 10:11 PM
are they anyway to check the igniter,I've been reading that it could be that also ,,thanks
rodneys
12-26-2003, 09:46 PM
Chg. the fuel filter,,doing the same.Could it be the idel control valve????
pikkagtr
01-01-2004, 05:38 AM
could be a thermostat problem
if it's broken u might run too rich and choke the engine before u really warm it up :smile:
rodneys
01-18-2004, 10:24 PM
Still doing the same thing,could it be that carbon has pluged up the port holes or the egr valve sticking a little??Always us 93 octane to thanks alot,
