No Ability to lube chassislinnibin 12-22-2003, 07:49 PM The 2000 Tundra has no ability to lubricate front end and chassis parts; therefore requiring parts replacements of high cost or wear and tear on tires, shocks, rims, brakes, etc. related parts, even after following the scheduled maintenance program, it has cost me a complete new set of tires at 40K miles. :banghead: Does anyone know who to have install zerk fittings to lube required parts? Any input would be greatly appreciated. Thank you. Tercel GTS 12-23-2003, 12:44 AM Drill a proper sized hole per fitting, they are pretty much self-tapping,. smear some grease over the spot you're going toSdrill, the flutes of the bit will draw the shavings awat from the hole. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
