Monte Carlo Z34 coupe 1998 where's brake switch at?Montelookup 12-22-2003, 04:27 PM Can someone please tell me how to reset the brake switch? I got 2 new bulbs, but that didn't help. The braking lights on the tail still arent' working. Anyone know's what else I can do and where the brake switch is, please reply, Thanks! Montelookup 12-22-2003, 04:28 PM Help!! dahl_berg 01-06-2004, 10:29 AM Does your lower brake lights not work, but the upper one does? If this is the problem, i dont think its your brake switch. But, for future knowledge, the brake switch is located on the brake pedal under the dash, you will probably have to remove a small piece of dash to gain access to it. I belice its 3 small screws that must be removed. When access is gained, follow the brake pedal upwards and you will see 2 switches, one is the brakelight switch, the other is for cruise control. The longer one is the brakelight switch, usually below the c.c. switch. But if your having the same problem i had, then i dont think its a brakelight switch. My brake lights quite working one day, but my third still worked, my hazards worked just fine, my blinkers worked(kinda) left blinker was faster than normal, but the lower brake lights just didnt wanna work. The problem ended up being the turn signal switch. This little problem will cost about $225 or so depending on where you live. For reference, the part itself costs about $65 w/o steering wheel mounted radio controls. I hope this helps you, good luck. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
