'96 740iL Electrical Noise Problemgsestep 12-22-2003, 10:20 AM I recently had my driver door window regulator replaced and the outcome was much more than a working power window. After completed, I had a low level hum in my driver door main speaker when the key was not "on". I also noticed a crackling noise in my tweeter in my driver side rear passenger door tweeter when running. The hum in the front door goes away as soon as power is applied to the car through the key switch. The crackling in the back tweeter occurs mainly while accelerating or when turning lights or electronics on and off while driving. To make the whole situation weirder, the memory seats no longer work. Also, when driving and "jamming" on the stereo very loudly, the seat all of a sudden moves to the "rearest", "lowest", home-like position. A pretty weird feeling while driving 80 on the interstate. Luckily I could still reach the peddles. After turning down the stereo, the seat can be adjusted normally but, again without memory. All symptons are completely repeatable!!! The body shop who did the replacement of the window regulator took the car to a car audio shop and they said the stereo amp was going bad. I think it is more than that. They checked the wiring harnesses and could not find any noticible shorts. HELP!!!!!! I noticed that most if not all of the wiring in the door goes through the window/mirrow switch console. Could something be wrong in this? Where is the actual memory positions of the seat located? Are they in the memory switches? libertylover 12-26-2003, 08:54 AM Based on my years in aircraft instrumentation in the Air Force, I'd say you have a bad ground somewhere, probably in the door. Inspect, clean, sand, wire brush, whatever it takes to get good grounds. Also, open the connectors and measure all pins that go to ground. Wiggle the cable to make sure the connection is rock solid. Once you find the problem, the fix will probably be easy, but finding it may not be an easy task. Good luck! gsestep 01-09-2004, 01:04 PM Well, I checked and double checked the wiring and cannot find a problem with the wires, connections or grounds. I am still wandering if the ground issue could be in the switch cluster in the door panel where all wires seem to come to. There must be more electronics in the cluster than just switches and mirror controls. Any other ideas out there? opcart 09-19-2007, 02:16 PM gsestep! Although your post was a while back I have a 1998 740 with the identical problem and if you happen to still see this post can you please tell me what the fix was! revtgl1 11-23-2007, 06:56 PM gsestep! Although your post was a while back I have a 1998 740 with the identical problem and if you happen to still see this post can you please tell me what the fix was! having similar problems, can you help......97 740i BAVARIANM 11-24-2007, 02:26 PM Commonly when someone is not familiar with these door panels removes one, they mix up the connectors. If you notice some of the connectors are the same. I can't tell you for sure without seeing it, but if someone has been in the door, that is the FIRST thing I'd check BAVARIANM 11-24-2007, 02:28 PM Does the one touch feature for the window still work? If not, the connectors are switched revtgl1 11-25-2007, 08:39 AM Does the one touch feature for the window still work? If not, the connectors are switched Yes the one touch door feature does work, but the memory selector switches do not....did making the switches fix your problem? And do you think there are more connectors in there that could be switched? Thanks in advance..... albertlzr 06-23-2008, 12:27 AM check the connector by the door hinges it should be an eight mm bolt ,removed it and disconect the harness and you will probebly see corrosion . '97ventureowner 06-23-2008, 12:56 AM Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date. From AF's Community Guidelines: POSTING IN CLOSED OR OUTDATED THREADS: If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread. Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread. The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html Closed. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
