1990 Cherokee Electrical Issues - Starting - Charging
Google
Web AF
Nummagumma
12-19-2003, 02:29 PM
A little history:
16 months ago this car had sat for 4 months, unused. It needed to be jumped to start. The battery didn't hold a charge. Replaced battery. Worked ok - but sat again for 2 months - no start. This time jumping it didn't work, and towed to shop. Computer died (probably during jump). Replaced computer. Replaced alternator. Ran fine for 10 months.
Blower motor fuse melts into fuse block. Pulled from block, wired around it, and put into Acc position. That position dies. FInally put it on a connection that's always hot, and it works.
Install a new aftermarket stereo on Friday. Car sits for 2 days. Monday morning, no start. Lots of jam in the battery, but just cranking and cranking - figure no spark, check plugs, check rotor... have towed to shop. Shop mystified - but car starts up mysteriously, and continues to start.
Next Sunday (after sitting for 2 days) - no start. Have towed to shop - replace all parts of the ignition system - no dice. Replace computer - works fine.
Day after getting car back with new computer - dies on highway coming home - electrical fading out, radio going in and out - fan running slow - battery running down - sounds like an alternator, right? Have towed to shop - diagnose and replace alternator, charge battery.
Next day, same issue.
This is where I am today... I'm mystified as to why this Heep has so many electrical issues... Can anyone out there shed some light on a possible cause?
richpinkham
12-20-2003, 09:44 AM
Check the Ingnition switch on the steering coloum and see if maybe its burned some of the conectors. maybe when they are replacing the computer they bump the wires and make the switch work again.?? I have replaced the switch twice in 70,000 miles and have had many prolbems till its replaced.
flurpo
03-18-2004, 08:16 PM
Hey Rich,
did you have to remove the instrument panel to get to that switch? I can see it underneath but it is Real touch to get to it. Afraid to try it as there is an adjustment necessary for getting it in right. Not sure how to go about this. Best,,,,, flurpo@ix.netcom.com
:loser:
Dale Aeppli
03-19-2004, 10:03 AM
A little history:
This is where I am today... I'm mystified as to why this Heep has so many electrical issues... Can anyone out there shed some light on a possible cause? HI, FIRST OFF YOU HAVE A ELECTRICAL SHORT SOMEWHERE,BYPASSING THE CIRCUIT DOESN'T HELP. CHECK OUT THE ELECTRICAL PROBLEM. THE SHOP IS JUST CHANGING PARTS. HAVE THEM CHECK THE CRANKSHAFT POSITION SENSOR. DALE
jeepman600@aol.com
Google
Web AF
