Sebring Keyless Remote Programing
Google
Web AF
simeon748
12-17-2003, 01:20 AM
I purchased an extra keyless remote for my 97 sebring convertible on e-bay. Does anyone out there have instructions on how to program this remote to my car? Thanks
stu777
01-30-2004, 10:09 PM
1995 - 1998 (FJ) Avenger/Sebring/Talon
Manual Programming Procedure (non scan tool)
1. Connect pin 1 of the 16-way data link connector to chassis ground or to pin 4 of
the 16-way data link connector.
2. Close all doors, turn ignition key to off.
3. Turn ignition key to Accessory.
4. Turn ignition key to off, door locks will cycle once (in programming mode).
5. For each key FOB, press any button 3 times in a row to program code. When
programming is complete, the door locks will cycle once.
NOTE:
IF A SECOND KEY FOB REQUIRES PROGRAMMING, IT MUST BE PROGRAMMED WITHIN 1 MINUTE OF
THE FIRST FOB PROGRAMMING. PRESS ANY BUTTON ON THE SECOND FOB 3 TIMES TO PROGRAM
ITS CODE. WHEN PROGRAMMING IS COMPLETE, THE DOOR LOCKS WILL CYCLE ONCE.
6. The programming mode finishes after the following:
a. Programming of two key FOBS is completed.
b. One minute has passed since programming.
c. Pin 1 of 16-way data link connector is removed from ground connection.
d. Ignition switch is turned on.
e. Any of the doors are opened.
Octoberfest
02-15-2004, 08:53 PM
How do program the keyless entry remotes for my '04 Sebring Convertible Touring Edition, I have 2 remotes now but want to add 2 more.
Alan Ross
07-23-2004, 03:44 PM
If I am not mistaken this procedure is for the FJ body (coupe), which differs from the JX body (convertible)
The difference is the FJ Sebring coupe & Avenger are products based on the Mitsubishi galant. They utilize a completely different body control module. The remotes are also different, somebody I know has a Sebring coupe and they are totally different.
Some of the other differences are engine management (164 HP vs 168 on 2.5) different a/c, abs, interior, exhaust, power steering, just to name a few.
There appears to be no pin one on the JX body Diagnostic link connector so I do not think that this procedure is the one that is being seeked.
I myself have recently acquired 2 replacement remotes & am unable to program using this procedure.
Does anybody else have the JX Sebring Convert. -JA Cirrus/stratus procedure?
grabijam
09-01-2004, 10:41 PM
Can anyone tell me if this procedure will work for a 2000 Sebring? I recently bought a remote via internet to replace the original which was lost.
NOTE:
tlamar2000
08-18-2005, 12:50 AM
I'm trying to program a remote. I have the instructions but cannot locate pin one. Where is it hidden?
Thanks,
Tyrone
tlamar2000@msn.com
Alan Ross
08-18-2005, 11:19 PM
What Sebring to you have, convertible or hardtop?
Google
Web AF
