cleaning battery terminalsholyniht 12-16-2003, 03:03 PM my battery terminals are starting to get corroded to the point, im sumtimes not getting enough juice 2 start my car till i wiggle the terminal sum. what can i use 2 clean off the termianls, i got the metal bristled brush already thanx in advance. GScivic7 12-16-2003, 05:11 PM that's all you really need, just scrub real hard and try putting some dielectric grease on there, it'll help a little bit. holyniht 12-16-2003, 07:33 PM k, thanks 4 the reply :) ra11585643 12-16-2003, 08:16 PM They do make a corroision neturalizer, but just mix arm and hammer with water and pore it over the terminals, it should foam and soften the caked on mess, it will make it easier to remove, and yes use the grease after you clean it all up. BullShifter 12-17-2003, 12:21 AM You can also pour hot water or Coca-Cola *classic* on the terminals for cleaning. The brush method would be the proper way. Ricochet 12-17-2003, 01:54 PM You can also pour hot water or Coca-Cola *classic* on the terminals for cleaning. The brush method would be the proper way. What he said. Coke and a toothbrush. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
