Remote trunk releasetrendar 12-15-2003, 07:17 PM I had a remote trunk release that wasn't disengaging, making the trunk stay open- After removing the actuator, I disassembled it and found that the helical gear was apparently worn a bit, allowing the gear to rub on the housing, preventing it from returning to the disengaged position. I put a small washer to space it out some, and it's working fine again- Pretty easy fix if anyone encounters this problem- azblock 05-14-2004, 06:12 PM my 96 caprice trunk release does not work at all, it did at one point. do you know of a way to fix it? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
