2000 Tracker Remote Programming
Google
Web AF
jaydee
12-14-2003, 05:05 AM
I found a thread with instructions on keylees entry remote programming for the 2000 Tracker, but the pictures are no longer posted. If anyone has info on how to program this remote, please send it to me.
Thanks in advance,
Jerry
99ssconv
12-14-2003, 10:06 PM
Programming the Remote Control Door Lock Receiver
Important
The vehicle comes equipped with two transmitters. The receiver can be programmed to accept up to four transmitters. Additional transmitters are available. If the number of transmitters programmed exceeds four, the previously programmed transmitters will be erased in order, starting with the first transmitter.
To program the receiver to accept the transmitter, follow the procedure.
Set the receiver to the reprogramming mode by installing a 5 amp fused jumper wire from cavity 8 (3) to cavity 4 (2) of the data link connector (1). The door locks will lock and unlock once to indicate you are in the reprogramming mode.
Within 1 minute, press the LOCK (1) and UNLOCK (2) buttons simultaneously until all door locks lock and unlock once each.
Important
Additional transmitters must be reprogrammed within 30 seconds of the previous transmitter.
To reprogram the next transmitter, press the LOCK (1) and UNLOCK (2) buttons of the transmitter (3) simultaneously until all door locks lock and unlock once each. Repeat the previous step for up to 4 transmitters
Disconnect the fused jumper wire from the data link connector (1).
jaydee
12-15-2003, 11:02 AM
Thanks, but this is the same information I found before. The problem I have is that I don't know what the connector looks like or where it is. I need the diagram that accompanied these instructions.
Jerry
Shortbus
12-27-2003, 09:08 AM
Here's your picture.
The location of this is Left side of the instrument panel inboard next to the transmission tunnel
http://files.automotiveforums.com/gallery/watermark.php?file=/503/37043keyless1.jpg
Google
Web AF
