no gas? - 88 F150 300ci 4.9L 6 cyltom_indo 12-12-2003, 03:42 PM ok i know there is good spark. no gas. i tried flipping the switch to the front tank and still no gas. fuel pump is new and functioning and new filter. what can i do other than spraying starter fluid to get this truck to lite up? is there a way to force air through the injectors to ensure they are clean? pete54ford 12-13-2003, 10:53 AM Dont know your ability on fuel injections...but, yes there is always a but, I myself would take it to a shop! If it starts with starter fluid I would lean to faulty fuel rail. But I'm not 100% on this. Please let me know what it was, when you find out. Thudpucker 12-23-2003, 07:12 PM Somewhere in the F.I. mess, there's a fuel shutoff in the Fuel rail. It's not opening. It needs +12 to pull up a solenoid valve. You are gonna need a book. Bronco2 12-23-2003, 08:13 PM Buy or borrow a "noid" lite-under $10 .The ECM may not be firing the injectors.Check your fuel pressure-just because the pump runs dosn't mean that the regulator is good. Check all the connections in the battery area-grounds are important.Hope this helps. mr_malina 01-03-2004, 05:21 PM There is a fuel cutoff switch on the lower part of the steering column. It shuts down the fuel supply in a accident. It could have been triggered. You can find the exact location in a owners manual or haynes manual. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
