My Car
Google
Web AF
jamesgregory244
12-07-2003, 11:57 AM
I would like to know why my exhust pipes turn red hot and my car gets real sluggish and likes to stall out.
99ssconv
12-14-2003, 10:09 PM
unburned fuel is causing the red hot pipes, youll havee to figureee out why the fuel is excessive, possible mass air flow sensor.
covvy
05-31-2004, 02:19 AM
If the manifold is glowing and the car will not rev then odds are that there is a restriction in the exhaust creating back pressure and the heat. If There is a dead missfire then it could cause the problem but most of the time I've seen this as a back pressure problem. Will it idle? How Does it idle and can you rev it? If it stalls when reving, get a vaccum gage and check the vaccum when loading the engine. It shoulb be about 20 in"hg at idle and 12in"hg (+-4in"hg) loaded (part throttle) If the vaccum drops off down steadily to nothing as the engine is loaded then there is a restriction in the exhaust. Could be the cat or the muffler. Good Luck.
Google
Web AF
