car not running in d4/d3???g2-gs 11-30-2003, 11:58 PM sup guys, today i was driving in D4 and all of a sudden my car just stalled. I pressed the gas pedal, the RPM jumped but the car didnt go anywhere. The car also won't run in D3 either but the RPM moved. I turn the car off and let it sat for like 2 minutes and turn it back on...but it still wouldnt work. It works in D2, D1, and R. You guys know what could cause this problem. thanks, JT HONDA_99 12-01-2003, 08:27 AM sounds like transmission problem. check fluid level, if its low add some and see if it helps. if that didn't helped, you need to take your car to transmission shop. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
