lower boost88zccivic 11-30-2003, 02:57 AM im putting a t-25 turbo out of an eclipse on my zc and i want to lower the boost to about 6 what are my options for this? someone told my i could bend the wastgate in a little but that sounds funny wouldnt that make the wastgate stay open all the time? i think that turbo runs 8 psi stock Rgacke 11-30-2003, 02:17 PM you can bend the rod in twords the turbo 1/4" to get around 5-6 lbs. 88zccivic 12-01-2003, 01:37 AM what about these manual boost controllers can you only raise boost with them? turbo2nr 12-01-2003, 02:23 PM you need the exhaust mainfold,all the plumbing, i think the t-25 has a internal wastegate, if not you can jus use a boost controller and set it for 6psi and maybe 8psi for racing i wouldt go higer then 8psi b/c then you will start to break things also dont neglect the fuel magament. 1 TEAM KLR 12-02-2003, 09:15 AM don't worry about any of that, spend your money on proper tuning items like a zdyne and run 8 psi, at least go with a apexi afc and 440 cc injectors, there is no replacement for proper tuning! b18-cYA 01-03-2004, 03:55 PM i agree with team klr vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
