bolt pattern 98' 4cyl ?ouzo 11-30-2003, 01:45 AM hi all~, i have the 98' accord 4cyl... what would be the bolt pattern, i know its 4 x ? ... also would i be able to change to a 5-bolt pattern, and add thicker tires? stocks are 15x6. -peash ;) BullShifter 11-30-2003, 02:03 AM STOCK TIRE SIZE: 195/65R15 BOLT PATTERN: 4 on 114.3(4.5 in) What do you mean by thicker? wider, taller side wall? 5 lug conversion would not be cheap, but it can be done. www.whalentire.com (http://www.whalentire.com) www.tirerack.com (http://www.tirerack.com) 92lx 11-30-2003, 02:29 AM 4x114.3 as stated, the question is why upgrade to 5 lugs unless you REALLY want a specific set of wheels, or you're putting out mega horsepower (even then 4 lugs will hold a lot)...... But it can be done, and no, it's far from cheap :) ouzo 11-30-2003, 03:23 AM ya, thanks for the info guys, i was skeptical that the 5 lug conversion was gonna cost alot, i was looking to add wider tires/rims, but wasn't sure how wide i could go with 17's, with out rubbing against the sidewalls, would 17x6 be too wide? BullShifter 11-30-2003, 07:25 AM You could use a 17"x7" with about 40mm offset STOCK TIRE SIZE: 195/65R15 (http://www.whalentire.com/tiresize.cfm?tiresize=1956515) Recommended Plus Sizes PLUS 2 SIZE(S) Require 17 inch wheels 225/45R17 (http://www.whalentire.com/tiresize.cfm?tiresize=2254517&manu=&finish=&vehicle=4441&sorttype=1&onhandlimit=1&boltpattern=0&diameter=0&smallwidth=0&largewidth=0&npp=0&crn=0&alt=no) 0.01 Inches shorter than stock tire 215/45R17 (http://www.whalentire.com/tiresize.cfm?tiresize=2154517&manu=&finish=&vehicle=4441&sorttype=1&onhandlimit=1&boltpattern=0&diameter=0&smallwidth=0&largewidth=0&npp=0&crn=0&alt=no) 0.36 Inches shorter than stock tire 215/50R17 (http://www.whalentire.com/tiresize.cfm?tiresize=2155017&manu=&finish=&vehicle=4441&sorttype=1&onhandlimit=1&boltpattern=0&diameter=0&smallwidth=0&largewidth=0&npp=0&crn=0&alt=no) 0.48 Inches taller than stock tire HONDA_99 11-30-2003, 10:14 AM get rims with offset not less then +42mm, if your car is dropped or you're planning on dropping it. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
