accord 92superredlude 11-23-2003, 06:13 AM any body replace the brake rotor for the 92 accord lx? need help. the prelude is easy just take out caliper bracket and screws, but the accord can't figure it out. krazibimmer 11-23-2003, 06:19 AM the rotors are press on. not the slip on type. you need the proper tools to take it off and recommend replacing the wheel bearing along with the rotors. 92lx 11-23-2003, 10:34 PM You'll probably want to take it to a shop, or if you have the proper tools you can do it. I recommend swapping over the Acura CL hubs while you're at it, they're not that expensive and you can then use Rotor-over-hub to your advantage :) - Nathan vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
