small block timingdrosblack 11-22-2003, 11:43 AM :bananasmi Any body know the right way to check timing for a 1972 small block chevy? I have a standard timing light but do not know exactly how to use. I found timing lines but they are very rusty. Is there supposed to be a reference line on this? hotrodtech. 12-12-2003, 08:32 AM there is a line in the harmonic balancer and you should have a timing tab on your timing cover, the big notch in the timing tab is 0, you can set the timing to 0 but i would suggest 4 derees, this is done easier with a timing advance timing light vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
