99 Jetta GL battery replacement problem
Google
Web AF
snakertman
11-18-2003, 11:47 AM
This is my GFs car so i know little about it. i replaced the battery and now the car will turn over but will not start. it seems like the anti-theft was triggered with the battery disconnect and won't allow gas to flow. Can someone help me out with this?
2001bluejetta
07-15-2005, 10:01 PM
Maybe check the alternator . Try to get the car started and take a multi meter across the battery and neasure the voltage abd see if you get 13 or more volts... Then the alternator is good.
hope this helps??
BluesCruiser
07-29-2005, 04:27 PM
try setting the alarm again the disarm it...goodluck
dataminor2
09-05-2005, 01:32 PM
I see this is a common problem. I just replaced the abttery on my 99 jetta mkiv and now the engine turns over but won't run. Anyone out there have any "help".
veedubmechanic
09-05-2005, 06:41 PM
Your car knew that it wasnt at a dealer getting the battery replaced so it decided to mess with you and shut off.
If the battery isnt the same cca as the vw one it might not start. I believe the factory cca is 540
RYES
11-22-2006, 11:02 PM
Did you ever find the problem? I'm having the same problem?
New2GasEfficiency
11-24-2006, 01:39 AM
I Replaced my battery and had a similar problem, it would crank up but ran really crappy like the timing was off, so i had a friend of mine who is a mechanic reset the computer( once the battery is disconnected it loses its memory, throttle body was actually my problem) after that was reset my alarm went off until i disconnected the battery... Would we did for that is disconnect the neg. cable and i had someone in the car and right as he tried to crank it i connected the neg. cable to the post... it tricked out the car into starting and havent had a problem since... so check and see if anything needs to be reset if not try the battery thing... sounds really retarded trust me i questioned it myself but it worked like a charm..
Google
Web AF
