Keyless remote for Avalanchetweetyboat 11-14-2003, 11:34 PM Avalanche Could someone please help with programming a keyless remote on a 2002 Avalanche? Thank you! 99ssconv 12-13-2003, 08:33 AM Transmitter Programming Procedure (Method 1 - No Tools Required) Close all the vehicle doors. Insert the ignition key into the ignition lock cylinder. Press and hold the door unlock switch. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF. Release the door unlock switch. The doors will lock and unlock to confirm the program mode. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter. Repeat the previous step to program up to four transmitters. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode. Operate the transmitter functions in order to verify correct system operation. usedcars48 03-11-2004, 01:06 PM Transmitter Programming Procedure (Method 1 - No Tools Required) Close all the vehicle doors. Insert the ignition key into the ignition lock cylinder. Press and hold the door unlock switch. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF. Release the door unlock switch. The doors will lock and unlock to confirm the program mode. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter. Repeat the previous step to program up to four transmitters. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode. Operate the transmitter functions in order to verify correct system operation. :smile: Thanks it works soooo easy. Kinda upsetting to pay a dealer the 65-85 dollars to get it done. Thanks rhinosmith 03-25-2005, 12:50 PM Thanks very much. I am far less frustrated and can afford a mice lunch! wolf1477 07-22-2005, 05:23 PM Thanks very much. I am far less frustrated and can afford a mice lunch! Ewwww ::shudders:: heh love typos and just couldn't resist. kcoaster 08-27-2005, 01:08 PM WOW! that was sooooo easy, thanks a million, now I can have a "mice" lunch. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
