HELP please88zccivic 11-10-2003, 10:34 AM hi i have an 88 civic and the other day i was driving on the highway and it started to shake so i went to pull over and then it started jerking very hard to the right even at 2 mph once i came to a stop i tride steering the wheel back and forth and it would go all the way to the left but only a littel to the right. i jacked it up couldnt find anything wrong and when i set it down it was back to normal? i drove it 130 miles home i also have an cv joint clicking if that helps im lost please help suspension mods: coil overs (lowerd 1") kyb struts strut bar camber kit 17" wheels 1600cc 11-10-2003, 10:51 AM Hermzz...sounds like the problem I use to have with my Isuzu. If you turn it all the way to the right or left, it clicks. That's not good, your boots are probably ripped too. You're gonna have to replace the cv joints. I paid about $450 for mine with the labor. The parts should run about $120 each. The prices reflect my Isuzu parts, your prices could be different (I don't know how significant). But I'm pretty sure it's your cv joints man. BullShifter 11-10-2003, 11:06 AM if the cv joints are bad, your better off replacing the axle insted of rebuilding - much easier. I would check the tie rods & ball joints also. while the car is lifted - grab the front tire & shake - if any noise or play, you then most likely have a worn suspension part.(ball joint, tie rod, bushing, etc.) its hard to say without seeing it. 88zccivic 11-10-2003, 01:50 PM thanks guys ill cheack all that vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
