Tail Lights
Google
Web AF
CAR IDIOT
11-06-2003, 04:27 PM
My Break Lights And Blinkers Work But My Tail Lights Won't Work For 1993 Camery Have A Lot Of Fuse Boxes I Didn't Know About Check Under Hood And By Change. Can Any One Help
89CamryV6
11-06-2003, 11:17 PM
Let me know what it turns out to be. Im having the same exact problem at the moment.
dongta
12-30-2003, 09:50 AM
brake and blinker lights are different from tail lights. Turn the lights on, have someone press on the brake pedal and see where the lights are located, just pry the black plastic clips off the fabric (and pop the white clip off also - don't worry you won't break it). twist the bulbs counter-clockwise and replace them. Check for the correct bulbs at any auto stores, I believe the 194 bulbs are the one. For the fuse, just take the coin box off (it's the one by the driver's left knee) by pressing both sides and take it off. There is a chart on the back side of the box that tell you the description and location of the fuses. There should be a white plastic clip for you to use to pull out the fuse, or use a small plier. Good luck.
Google
Web AF
