Eww what the hell is this noise?
sparq
12-10-2001, 08:02 PM
Ok call me crazy... but the cold weather is doing some nasty things to my dads CR-V... (2000 model w/ leather yadda yadda) well anyways I was taken her for a spin today and I slipped the front wheels and I guess the CR-V has that 4 wheel system and like the power was switched to the back or whatever the hell it does ~ but it was the MOST disgusting metal screaching noise ~ WHAT THE HELL IS THAT? It sounded like I curbed some rims real bad... but I wasnt near a damn curb, and I managed to do it again when I wanted to know if I was going nuts or not so I found some slippery stuff (ewww yeah it snoed up here!) and yanked the wheel and gunned it and sure enough it did it again!
The noise is coming from the rear... just wondering what the hell is going on ~ its a 2000... things arent supposed to be broken yet! hahaha, anyone got some ideas before I can talk dad into bringing it down to the dealer?
1989 DX R
12-10-2001, 09:38 PM
I think it could be the diff slipping, i dont think Honda's got a locker on the CRV
MugenCrVTuner
12-11-2001, 03:55 PM
The noise you're hearing is the rear differential....if it continues to make whining noise change the rear diff oil...that'll solve your problems...but not permenantly though...you'll probably have to change it every 30 or even maybe 15 thousand miles....Honda messed up with the rear diff......
sparq
12-13-2001, 05:48 AM
That might explain it... its got 36k on the ticker already (hehehe we use it for the NY-Florida runs :) ) Of course dad wont listen to me, gee he doesnt hear the noise ~ gawd whatever, someone come to Syracuse and steal his car, he doesnt deserve a Honda
Dad = :flipa:
MugenCrVTuner
12-14-2001, 11:57 AM
hahaha....just change the oil without him knowing if you really want....cause if you don't...my friend's V had to get it replaced because he didn't change it....he was just an a$$...too lazy...anyhow...it ended up to be about 1,500 for the stupid diff and labor...so...watch out for that....good luck!
90CRXZCSi
01-31-2002, 01:16 AM
Yea probably the rear differential. As you noticed, honda didnt make many AWD cars because of that. They are mostly front wheel drive because they dont wanna deal with drive shafts and yadda yadda. Wait, but i guess they did make the S2000.:D
SkyNex721
02-03-2002, 06:50 AM
Wrong again genius. Honda did make AWD cars. The 4th gen civic wagons were AWD.
jOYRiDe
03-08-2002, 01:49 AM
:spit: youre messing with the wrong nigga (no offense) 90CRXZCSi
89ssgti
03-08-2002, 12:32 PM
omfg rotflmao:hehe::biggrin2:
sparq
05-29-2002, 10:08 PM
Just thought I would bring this up again... still havent gotten the noise checked out, only happens when the cars turning with the wheel all the way to the side and im goosing it... or when I mash it and I have no traction. Oh well, dads getting rid of it anyways :flipa:
w00ters
11-21-2002, 12:39 AM
i am a honda tech at a honda/acura dealer... it is the rear diff fluid it needs to be changed every 15k or so.. i do it almost daily here.. jsut go to honda get a qt of dual pump fluid and a gasket. it takes one qt that will take care of it. if its been squeaking for a bit now, you might need to do it twice . :)
caniac1
01-28-2003, 02:23 PM
I had the same noise in rear end at ~ 40 K on '99 and the "Honda Specialist", said there is a bulletin to change the differential oil with a thicker (more viscous) type have not heard the noise for 10K miles!
BullShifter
05-25-2003, 01:22 AM
Service bulletin says to flush & fill the rear differential 3 times & if the noise is still present - next step is to replace the rear diff. The noise is most common when making sharp turns at slow speeds
Honda messed up with the rear diff -thats not the first, honda has been messing up stuff since 98.
lorunner
05-27-2003, 05:08 PM
replace the rear diff and use the dual pump fluid only need to do it once no need to flush it. If it doesn't fix it the first time then you already have a problem.
