Low Gas Mileage
Google
Web AF
kishore101
10-30-2003, 06:30 AM
HI all,
I recently purchased a 99 Camry CE 68,000 miles.
After i bought i came to know that gas mileage on highway is 21.5mpg and 15mpg on city. I know it is terrible for camry.
So i took it to mechanic. he says O2 sensors are the problem. Struts need to be replaced. Is it possible to get low mileage just because of that?
I smell something unpleasant near the engine. When i accelrate slowly my i feel the gear change which is unusual for camry.
Thanks for the help.
Chris
fatninja19
10-31-2003, 08:28 PM
I doubt the worn out struts would affect your mileage, but the malfunctioning o2 sensors would cause you to run way rich, resulting in shitty ass mileage..
also check your tire pressure and see when you need to change the oil and stuff in your car. Some fuel injector cleaner would probaly help as well.
Bossman
11-01-2003, 12:45 AM
Change your fuel filter also. You don't want to exceed 30,000 miles on one.
If you're flat-spotting tires, meaning you are getting a smooth patch on your tires, then the struts will need to be replaced. It happened to both of my Camrys and it took care of the tire problem. However, it didn't have any noticeable effect on gas mileage.
Your O2 sensor will need to be changed if your "check engine" light comes on. Maybe a second opinion from another mechanic would help diagnose the low mileage problem.
kishore101
11-04-2003, 09:35 AM
hi guys,
Do i have to buy O2 sensors from Toyota or is it good to buy anywhere?
Thanks for all your input.
sidler73
11-04-2003, 10:01 AM
Simpler, and quicker way to find out. Ask your local dealer the ohm resistance spec on your 02 sensor. Pull the wire test it with one end on the 02 the other on ground ...Voila' it is either within spec or not...take appropriate action. example (.8 volts- 2.8 volts etc....)
Hope this helps.
Also you can buy them anywhere...once you learn how to test them(takes about 10secs) you can go to a local auto wrecker and buy for next to nothing.
Good luck!
89CamryV6
11-06-2003, 11:21 PM
change your air filter then look in your manual on how to use your diagnostics port under the hood. all you need is a paperclip to bridge 2 terminals which makes your check engine light flash trouble codes if any sensor is bad.
kishore101
11-11-2003, 08:04 AM
I changed the Air Fuel mixture and still checking on actual mileage.
But another thing i noticed is that when i accelrate i feel jump forward as if the transmission was changing gears suddenly.
What do u think is the problem?
Thanks a lot guys.
Google
Web AF
