1999 le DRL's
Google
Web AF
nitro420
10-28-2003, 09:04 PM
how do i disable my DRL's on my 1999 camry le? any help would be greatly appreciated ... thank you
sidler73
10-31-2003, 08:23 AM
Emerg brake will disable the DRL module from turning on.
Other wise on that model on the left hand side of the firewall you can just unplug it. It has a fins aluminum and about the size of a cig pack.
kuroi_tuki
12-23-2003, 03:57 AM
can u take a picture of where the plug is???
i couldn't find the plug................. :banghead: :banghead:
Thank You
yotatechie04
12-23-2003, 08:28 AM
The Daytime Running Light module is located on the left upper end of the engine compartment. It's right by the diagnostic port, as stated in last post, it is a little aluminum box, no bigger than the size of a cigarette pack, with fins sticking out from it saying "Hot! Do not touch!" on a little yellow label. It won't be that hard to find, just right against the firewall. It's the only aluminum box under the hood with only one electrical connector running from it, all you have to do is unplug it. To make it easier, it's on the passenger side of the firewall, right below the windshield.
Google
Web AF
