turbo kits for the is300
Google
Web AF
boostedcivic
12-09-2001, 03:03 PM
Anyone know a company that offers a kit for the is300 that runs an external wastegate and a decent size turbo?
any help would be great
s0yb0mb
12-14-2001, 05:05 PM
there are no "kits" available yet... only IN-house installs. The kits will come shortly I'm sure, but there's more to just bolting on a turbo and goin, you'll need electrical mods and probably some tranny mods to support the loads. (depending on if you're running an auto or manual)
b16b bomber
12-15-2001, 05:54 AM
There are only inhouse turbos so far and i think the stage 1.5 runs around 10Gs
boostedcivic
12-15-2001, 01:11 PM
I know it's more to just bolting on a turbo kit, I understand that a clutch, diff. and fuel managment will need to be installed.
I have many years of turbo's on Hondas, acuras, supras and 300z's plus more. I am a tech and have a great knowladge of electrical and mechanial towards import cars. I was just looking for someone that maybe had a kit to save me time, or someone that would sell a headgasket, turbo manifold.
The shop i work at we already make charge pipes, have the turbos,wastegates,bov,fuel controllers,injectors etc.
but I was looking for someone out there that might have more info than in house only. Who makes the turbo manifold, headgasket, etc...????
Thanks a bunch
s0yb0mb
12-18-2001, 08:48 AM
if you planned on doing it yourself, you can get all the parts off the shelf I'm sure... the only real issue is your fuel/electronics management... which isn't easy to do. You'd have to ditch the stock ECU as tuners are having issues w/ the ODBII.
boostedcivic
12-18-2001, 09:13 AM
Thanks for the info, Iam planning on doing it myself along with another tech I work with that has been a lexus tech for sometime now.
The main concern is where to get a head gasket and turbo manifold from off the shelf??
fuel managment , I might try the same as what we do with the hondas but If that doesn't work out always can go Haltech or something like that.
i have worked with the haltech before and i like it , I use it on my honda.
also what size injector you think I should use? want to run around 10lbs pump gas and race gas maybe 18-20
s0yb0mb
12-18-2001, 10:30 AM
I'm not techinically inclined enough to tell you what size injectors to use, but I know you can probably get the head gasket from HKS (the IS uses the 2jzgt block found on the supra n/a, the gs300) and I'm not sure about the tubo manifold.
I think SRT is switching to a haltec for their supercharger...
Google
Web AF
