service engine soon light
timbo980
10-24-2003, 08:41 PM
Is there a way to reset the service engine soon light on a 1999 silverado without it code scanner?
GMMerlin
10-26-2003, 07:06 AM
Have you diagnosed and repaired to cause of the light coming on first?
If not, turning the light off only masks the problem.
timbo980
10-26-2003, 10:21 AM
truck was running rough put some injector cleaner and octane bost i it and it fixed the rough part but then light came on i believe it was because of trash in injector that caused prob it has happened before
BOOZER
10-26-2003, 03:06 PM
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
