95 GLE hard to start when warmed up
Google
Web AF
dt29332
10-20-2003, 10:34 PM
I have a 95 maxima that I love except for one problem. Sometimes the car won't start. It never happens when the car is cold; only after it is warmed up. Also, it doesn't always do it. Maybe 1 in every 5 hot starts. It never happens back to back and after 5 minutes or so, it will start (although you have to rev it up to get it to idle smooth). Once the car is running there are absolutely no problems: no hesitation, no rough idle. After the last time it did this, the check engine light came on. I took it to the shop and they said both O2 sensors were bad and the nock sensor was out. they also said the starter was going out. 2 days after replacing the starter and both O2 sensors, it did it again. Any thoughts???
Also, had the fuel filter replaced.
la300zxtt
10-22-2003, 03:18 PM
i would have said the igniton switch my friends did that when he bought his 95 max se it was tricky to start..
Google
Web AF
