cold air intake caused check engine light HELP!!
Google
Web AF
bobdotson
10-14-2003, 02:54 AM
i just installed a new weapon R cold air intake on my 1997 tacoma 2wd auto. and my check engine light came on i have already went and got it checked out and it says P0171 System too Lean (Bank 1) and when i accelerate it is lacking power untill like a little while before it changes gear then it has a lot of gain in speed. also i reset the codes cause someone told me to do that and the light turned off and came back on with the same code a while later.
PLEASE help me!!
thank you all,
BOBBY DOTSON
:iceslolan
FasTRDTacoma
10-15-2003, 12:22 AM
did u make sure that u put the oxygen sensor back into the intake? If your intake dosnt have a port for it, then i dont know what to tell you, because there is no way to "trick" the engine without it running bad. I suggest getting a K&N because they have the oxygen senor.
bobdotson
10-18-2003, 07:39 PM
yes everything that was taken off the old intake was put back in the new one.
nickbo
01-31-2004, 11:46 PM
I had this same problem when i put in my k&n intake, $170 later, this is what i figured out:
my K&N uses an oil to coat the filter to help keep out dust and the such. some of that oil got in the sensor, and was causing it to act funny. all i needed to do was pull it out and very gently clean the sensor. this should help, another option is that you will have to replace it. you may have damaged it in the re-install. hope this helps
LiLDaddyblackburn
02-06-2004, 04:39 PM
I put a cold air intake on my truck and the same thing happened....so i took it to a toyota dealer and had them to check it out and they couldnt do anything bout it to watch it and see if it goes off....so bout a week or two later it went off.
LiLDaddyblackburn
02-06-2004, 04:41 PM
Our yea just dont run it hard for a week or 2 thats what i did....and run the highest test gas in it
judgemills68
02-15-2004, 04:10 PM
get a injen intake. They seem to work best with tacomas. My crew has supercharged tacomas and we all run injen intakes.
redtoy92
02-16-2004, 02:50 AM
just screw the shitty air intakes and do a $10 deckplate mod! go to gadgetonline to see the dynos of the deckplate and the air intakes system! RED
Google
Web AF
