Ready to pull my hair out
Google
Web AF
vman357
10-14-2003, 02:43 AM
I replaced the eng and tranny in my full size 90 Blazer with a crate 350 and rebuilt 700r4,both from dealer.the old engine was running,but had a bad knock..OK... I installed a new fuel pump,filter..But the problem is I'm not getting fuel to the TBI now..I don't get it,it worked before!!
there isn't any power getting to the fuel pump,the fuses are good,everything is pluged in,fusable links are good,relay is good.
I ran a wire from the positive side battery term to the fuel pump,and the pump pumped,but still nothing at the TBI.
But when I try to get a code from the ECM,the check engine light is not on,the bulb is good. CAN SOMEONE PLEEEEEEEEEEEEEEEEZE HELP!!!
Thank you for your support!!!!
Doug
GMMerlin
10-14-2003, 07:34 AM
The SES light should come one with the key turned to the run position...does it?
You may have left a wire loose during the engine swap...happens....check the grounds!
Remove the injector connector and install a test light..spin the engine over..does the light blink?
vman357
10-14-2003, 11:11 AM
Thanks for your fast response!!!!
That's kinda what I was thinking,something real easy and often over looked... I'll try it tomorrow,since the truck is outside and it desided to rain today!!!!
I'll let ya know what I find...
Thanks again for your support,
Doug
Google
Web AF
