Door panel removalgreggk 10-13-2003, 01:10 PM When attempting to remove the door panel from a 2003 Tundra, something is holding it on right where the door handle (inside) is located. What am I missing? ToyTundra 10-14-2003, 06:09 PM on the fornt doors there are two torx screws behind some plactic caps. They are behind the interior door grip. I popped mine off with the blade of a knife. embpro 03-24-2005, 12:59 PM When attempting to remove the door panel from a 2003 Tundra, something is holding it on right where the door handle (inside) is located. What am I missing? Did you finally figured out? If so, help! I have the same problem. Even the 2 Torx crews have been removed, something behind the door latch still holds back the door panel... ToyTundra 03-24-2005, 02:34 PM Did something behind the door latch still holds back the door panel... the plastic trim around the door handle/latch contraption can be pried off, but be carefull it's easy to crack. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
