95 toyota corolla starter location
Google
Web AF
jliang128
10-12-2003, 03:41 PM
Where is the location of starter in a 95 toyota corolla? 4A-FE engine. The steps to remove starter in Chilton toyota corolla 1988-1997 repair manual:
1. Disconnect negative battery cable
2. remove air cleaner assembly (with hose)
3. disconnect all the wiring from the starter terminals
4. remove the starter mounting bolts. remove the starter
But I can't find starter after removed air cleaner assembly, please help
Thanks!
John
shahn31
10-22-2003, 10:47 PM
I know this is 10 days after your post, but the starter should be located underneath the throttle body in the middle of the engine. Good luck!
Google
Web AF
