abs light in 93 cavalier
Google
Web AF
krchutes
10-04-2003, 10:17 AM
I have a 93 cavalier with 72,000mi and the abs is coming on but brakes were okay til today. They locked on me today. Any suggestions?
krebs128
10-06-2003, 04:52 PM
new brakes maybe. the abs light usually comes on when they are in use, like braking really hard on rainy/icy roads.
94VL
11-12-2005, 07:42 PM
Probably a bad wheel sensor.There are 4 of them.
chevyguy93
11-13-2005, 12:15 PM
chances are its the wheel sensors. mine does the same thing. I replaced the front two, but good luck doin the back ones. It's a whole assembly, you strip a bolt, your screwed. So i just left those, still does it. Finally i just took out the light in the dash for the abs.
AssDust
11-14-2005, 04:20 PM
could be your relay for the abs. Try that
chevyguy93
11-15-2005, 12:56 PM
Aint the relay, because i can hear it clickin to turn on. However, i only have the problem when it turns on, (which is when i go over about 30km.) . I did some research, and figure that there is something wrong with the hydaulic pump. So i guess i will just leave it since it's too much work to replace.
dominoid8
02-27-2008, 03:58 PM
Check to make sure that your rear brake shoes and adjuster springs are not in backwards! Mine were and making my abs light come on. It won't hurt to look! I own a 1994 Chevrolet Cavalier RS with 2.2 liter 3 speed automatic,i have the exact specifications
Google
Web AF
