1993 S10 Blazer Digital Cluster Problemststorey 09-30-2003, 06:47 PM The digital cluster is not showing oil, battery, water or tach. All other gauges are working. Have already checked fuses, grounds, bulbs, circuit boards, no luck. Have torn the dash apart so I have access to everything. Good thing too. Heater core is starting to leak. Go figure. :shakehead Anyways, any help on figuring this one out would be greatly appreciated. airforceone 10-01-2003, 04:29 AM i have a 92 and mine has the same problem. not all that, just the odometer. i knew a guy that had a 93 with the same problem as you, i think it's a problem with the contectors. let me know if you fix it! tstorey 10-05-2003, 10:08 AM Well after spending all day in the u-pull it yards, only found one vehicle that was a twin and naturally the dash was gone. Did your buddy have the electronic digital dash with the one connector or was it the one that has the speedometer cable attached? airforceone 10-06-2003, 12:07 AM i'm not positive, but his was just a connector if I recall. Mine is just a connector. lesnyd 10-07-2003, 03:30 PM The digital cluster is not showing oil, battery, water or tach. All other gauges are working. Have already checked fuses, grounds, bulbs, circuit boards, no luck. Have torn the dash apart so I have access to everything. Good thing too. Heater core is starting to leak. Go figure. :shakehead Anyways, any help on figuring this one out would be greatly appreciated. Try these: http://www.mrwhizard.com/index.cfm and http://www.instrumentclusters.com/ Good luck! Larry benwa 01-15-2004, 02:40 AM E-mail caferacer1@comcast.net. He sells repair kits for those dashes. I' am glad I found him because the dealer said it would cost around $300.00 for a new rebuilt dash. luvmyfrizbee 05-20-2005, 09:13 AM i have a 92 and mine has the same problem. not all that, just the odometer. i knew a guy that had a 93 with the same problem as you, i think it's a problem with the contectors. let me know if you fix it! I got my 92 Tahoe dash working with a rebuilt cluster from mandigital on E-Bay and it worked great. Real cheap too. Here's the link. http://feedback.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewFeedback&userid=mandigital&iid=7974250704&frm=284 blandstyle 05-22-2007, 10:01 PM ive got a '93 with a completely black instrument cluster, from time to time it will come back on and all the gauges work. i have heard that there is a problem with these digital dashes linked to the horn. i am wondering if anyone has heard of this or knows anything about how to fix a dead dash. thanks! ZL1power69 05-22-2007, 11:11 PM welcome to af. this thread is almost 4 years old. please refrain from posting in threads over 6 months old. feel free to start a new one in the problem diagnosis section. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
