99GT Low Coolant keeps flashing!!
Google
Web AF
Moser28
09-26-2003, 11:57 PM
My low coolant light came on the other night so I looked and it needed some so I put the Dex cool in and looked for leaks but didn't find any...it's been about 5 days now and everything is fine other than the fact that my low coolant light keeps flashing. What do I do? My coolant isn't low, I;'m not running hot...what gives?
Thanks!
:screwy:
Ripn12s
10-01-2003, 05:50 PM
have you tried disconnecting the battery?? if not disconnect it and let the car sit for 30min - 1hr. Plug back in and see if the light is still on.
If it is maybe the sensor is bad?
Tim
Moser28
10-01-2003, 11:51 PM
I did disconnect the battery, only for about 5 minutes and the light still comes on. Where would the sensor be if it needed to be replaced?
Thanks!
The Burning Rom
10-02-2003, 11:50 AM
The battery needs to be disconnected for at least an hour to reset the trouble codes.
GMMerlin
10-02-2003, 12:17 PM
You may have a bad low coolant module....it is located on the radiator tank below the radiator cap.
Google
Web AF
