mgb oil leak at filterwing123 09-25-2003, 02:12 PM I've tried everything whats the trick to stopping the oil leak at the oil filter support arm where it attaches to the engine block. MG Merlin 09-30-2003, 10:55 AM Sorry, I can't really help you, but I can say what I know. If it ain't leakin', it ain't British. Drexel_quentin 10-07-2003, 12:23 PM Have you replaced the seal? sandrunner 11-16-2003, 12:06 PM Replace the seal and use a little gasket maker around the edges. If you can afford it buy one of the remote filter kits. Much easier to change the oil. Leaking British cars are a sign of careless work. Corgitoysaver 02-08-2004, 10:23 AM Look for hairline cracks in the mounting base Raymond. Jagboy69 04-15-2004, 11:44 PM If you are cranking the bolts down REALLY hard, you are killing the gasket... Are you using a good gasket sealer?? I use permatex aircraft sealer.. (comes in a little jar.. stuff is nasty brown) follow the instructions and use a new gasket.. If it's not cracked then this stuff should fix it.. I have never had a leak yet.. jazzydo 06-21-2007, 10:38 PM For this same problem, how much should you torque the square filter and oil filter adapter down? Thanks, Jazzydo vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
