Knocking sound
Google
Web AF
echo710
09-24-2003, 10:06 PM
I've got a 2000 chevy tracker and i've recently started to hear knocking sounds coming from under the hood, it only happens while going uphill, then starts to struggle at about 50-70mph, the sound gets louder when the a/c in on.It has the correct level of engine oil and transmission fluid. Although due for an oil change, what could possibly be causing the knocking?
szabotage
11-13-2003, 08:16 PM
if its a knock you hear it could be your crank
if you hear a clack its your valves
but if you hear a ping then use a higher octane fuel
pinging occurs when you put the engine under load while using crappy fuel
Google
Web AF
