Fuel PumpLeonard500 09-21-2003, 06:54 AM I have 97 GT 3800 V6 that will not start...I do not hear my fuel pump working, is there something that will shut down the pump or is my pump dead...fuse and relay are new. I appreciate any input and advice.... thanks Leonard omicron 09-21-2003, 09:40 PM Possibly the fuel pump it's self, or the fuel pump resistor has givin out on you. It's a conspiracy.... GMMerlin 09-22-2003, 12:12 PM Unfortunatly your fuel pump has met an untimely death. To verify the wiring, relays and fuses, (using a test light) check for power at the gray wire to the pump when you turn the key on or spin over the engine. If you have power, than the pump is bad. Leonard500 09-23-2003, 05:58 PM Thanks GMMerlin & omicron...I put new fuel pump in and started right up,the gray wire test was the key to solving the problem...there is 4 wires coming for the pump. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
