Surging
Google
Web AF
Cokeroker
09-18-2003, 12:43 PM
Anyone know what could be causing my surge problem? I have a 2000 Grand Prix SE. Have replaced the battery, the gas cap, transmission flushed and filled, fuel injection cleaned, fuel filter, and the Throttle Positioning Sensor and the surge came back. It varies from 2000-2500 RPM when it does it so you can imagine that it definitely can be felt. It mostly occurs in a slow acceleration. Goes away when I kick it down into overdrive passing someone. Help
Ripn12s
09-18-2003, 07:06 PM
could it be misfiring??
gtp 2000
09-18-2003, 09:49 PM
i agree with the previous statement, it could be a misfire of some sort
Cokeroker
09-19-2003, 04:20 PM
the plugs are only like 40,000 old... same as the plug wires.... you guys think that maybe a bad plug or wire.... maybe worse.... a coil?
mytwopointeight
09-26-2003, 12:59 PM
my s-10 did that and it was a vaccum leak, i dont kno very much about Grand Prix's but that might be it
roberts5
10-20-2004, 07:45 PM
My 1999 GP GT is doing the exact same thing. Have you fixed your problem yet? If so, any info would be appreciated.
Thanks,
Greg
supreme_style21
10-26-2004, 02:42 AM
Hmm.. I am also experiencing this. I was going to throw a TPS at it, but hearing as how it didn't fix your problem, I'll hold off for a bit. I've got brand new Delco plugs and wires, fuel filter, and one coil. Are you noticing it get progressively worse? Mine is at the point to where I'm very hesitant to drive it.
hoopsGTP
05-13-2009, 01:00 PM
I Have a 2001 GTP that does the same thing. Surges enough to see the RPM increase 200-500 RPM, disengauge TCC and problem stops. HAve installed Wires, Plugs, FF, AF, PCV, Inspected for Vacuum leaks, Vacuum 20inHg and steady. Tranny died, so swapped in a new one. Still has original issue. No codes, Scan tool reveals nothing of misfires(even slight ones) or EGR, or TPS eratic. TCC Slip is 66-120 RPM under a load. Pulled off Trans Side cover and replaced the TCC pressure regulator O-Ring per TSB. Fuel economy dropped from 28 MPG to 21.3 MPG and that aint because my foot is init either.. Thoughts????
doctorhrdware
05-13-2009, 03:01 PM
Are getting a check engine light. If you are, you need to pull the DTC and post them if there is any.
richtazz
05-13-2009, 03:20 PM
Pull the IAC valve off of the throttle body and inspect it's pintle as well as the bore it rides in for excessive carbon deposits.
hoopsGTP
05-14-2009, 02:47 PM
No DTC's, Pulled IAC out and all looks fine, no excessive carbon. I found that when I am running around say under 70 MPH the TCC engages and disengages, but say above 80 no problems, except a vibration. The surging occured before tranny replacement and after with two different TC's. I think it is PCM telling TCC to disengage, but why? what could be telling it that, I have looked at all sensors, misfires, MAT, MAF, IAT readings all looks OK.
tblake
05-14-2009, 08:26 PM
How long ago were the plugs replaced? What brand? What Gap?
hoopsGTP
05-15-2009, 07:52 AM
Plugs less than 10K miles, Plug Wires less than 10K miles and all GM. set to the gap listed in the SM. I think it was .060. Pulled and inspected about 1K ago, no carbon tracking on insulator nice and clean on the tip.
tblake
05-15-2009, 10:30 AM
were they delco iridium's? 41-101's? I've heard of delco plugs lately having issues with the porcelin cracking causing issues like you describe. I hope they weren't bosch, Rich can tell you all about Bosch. Same with delco rapidfire plugs.....
hoopsGTP
05-15-2009, 01:12 PM
UM, I believe they were the Iridiums, 41-101. I thought they were made by NGK though and resold to GM. Any idea what I should place in there as I was going to replace with NGK or Rapid Fires.
tblake
05-15-2009, 07:50 PM
41-101's should be good! However those are the ones that are suseptible to cracked porcelin. Did the surging happen after the plug change? I would pull all the plugs out and have a look at them. Check the porcelin and compare the tips.
NGK plugs are good, delco rapidfires IMO are not.
Google
Web AF
