What should i do next, i need help!jpj2176 09-15-2003, 09:11 PM i have a 97' jetta gls. and so far i have put on a eurosport racing intake, eurosport cat back, eurosport wires,eurosport underdrive pullies, autotech 268 degrees cam, neuspeed chip, eurosport short shifter... so now im wondering what to do next and i do not have the money for a turbo or supercharger. is there a good pair of headers that anyone has experience with, or does anyone recomend a certain ignition, is there a high flow cat, or is a cam gear some thing i should look into. im kinda stuck right now and would just like some advice.....thank you! v/r Justin jpj2176 09-16-2003, 02:04 PM i see that people are looking at what i posted but i would really appreciate it if some one could give me some advise, on where i should go next. v/r justin HanzNY 09-16-2003, 02:42 PM It sounds like you're off to a great start! Maybe you should just hold onto the cash until you have a big enough $ pile for a forced induction system. If you go with a turbo you'll have to swap that out anyway. I know, I know, you, me and everyone else wants everything right away. Somethings (big mods) are worth waiting for. Make an induction decision, hang in there and stick with it. Soon enough you'll be happy you did! jpj2176 09-17-2003, 04:29 PM if i was to go that route which system would you recommend? i have seen the eurosport, and the nuespeed is there other systems out there i should look into? v/r justin HanzNY 09-17-2003, 06:16 PM Unfortunatley, I don't have any hands on experience for your project, I'd only be guessing.:frown: This looks pretty cool:http://www.gmpperformance.com/products/engine_parts/neuspeedsupercharger.htm jpj2176 10-04-2003, 10:43 AM today i ordered the reative header, and the kent cam gear so i guess i will se what happens now.... and is there a high flow cat. or should ijust hollow it out the one i have now and buy a new one for inspections? v/r justin termitesgraffix 10-06-2003, 03:29 PM You are at the point now where i would agree with the last guy and say save your money for a while. With all that performance something is very likely to go on you, or you will be having fun and crack, you know? If you don't have enough money to buy a turbo, then how do you plan on replacing you heads or drive train when you rip out a gear or two??? I hope this isn't your only car. Take it from experience, I have an 84 Rabbit and a 77 Chevy Malibu totally hooked up. I was a dumb kid years ago and only had the malibu as a daily driver. Close to broke from all the work i put into it and i blew the engine and am now on my third engine. It goes quick man when you are having fun. If you insist on buying something though, I would say go with a new differencial to put those horsies on the road harder. Even think about throwing that clutch out and throwing in something stronger with more pressure to handle the extra HP you are putting in. jpj2176 10-07-2003, 04:13 AM i just want to thank the last guuy that responded because now tha you say that i can understand what you r saying and i am going to look into a new clutch now. it makes alot of sense and it is something i over looked i thank you very much. v/r justin termitesgraffix 10-07-2003, 09:50 AM no prob man... alot of people do.. that is one big thing that they overlook and is a VERY important part.. i meen whoa LOOK EVERYONE I HAVE ALL THIS POWER IN MY ENGINE, but it all disapears mysteriously when my stock clutch can't handle the new torque. Yea my friend chipped his TDI and man does it move now OH Hells yea... but thing is oops the clutch went in like a month... now he is throwing a VR6 clutch in there and he will be passing people left and right. Just the same (IF) anyone of you is thinking about caming out your automatic cars, or putting more power in them; keep in mind that the stall on your torque converter is set for the cam lift... if you change the cam you MUST change the torque converter to a compatible stall, or else you will be hesitating at idle cause it isn't slipping enough for the heavy lobe, stalling out, or your take off will be slow cause the new cam is made for higher end power and you are trying to take off on low end still.... Good luck man vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
